Intake cover
Hot Ducer
Atlanta Ga
Can the intake cover be removed just by removing the couple bolts right on top of it? I was going to clean the PCV valve on my lunch break but when I saw it was bolted on figured I'd leave it until I got home in case it was more in depth than that.
2003 1500 QuadCab 5.7 4x4
Mbrp.Ram
NW Indiana
5.7 Hemi. Mbrp catback, k&n cai
Are we talking about the intake box? The cover of the intake box? Not quite following. The box itself comes off in a few steps. Remove negative from your battery if you're a clutz hah. Take off crank vent, remove air flow sensor. Be gentle with that, remove from manifold, and there's just a couple bolts or screws holding it down
