Interior water slush sound
BobbyB
Magnum V8 5.2L
It comes from the passenger side. The water slushing sounds pretty much upon acceleration, it seems to be within the dash and it sounds like its inside the cabin. No recent rains. I also noticed this morning water dripping on parking lot from the passenger side, just about the level where a passenger would put his feet. No engine components there.
Any help?
Sent from my C5170 using Tapatalk 2
B
BobbyB
Magnum V8 5.2L
Oh and the carpet at passenger feet is soaking wet
jlynch34
Ac definitely clogged get it drained, happened to my jeep compass, didnt have to replace any wiring so I got lucky
Sent from my SCH-I545 using Tapatalk 2
B
BobbyB
Magnum V8 5.2L
How do i drain the ac?
Do u mean just unclog the drain tube?
WhiteExpress
Midland, TX
Yup, get under the truck with a coat hanger and gently clear out that little drain tube.
ss12108
New York
Hemi 5.7 8 Speed
You didn't recently get into an accident or anything did you? My buddy had this exact same issue in his Wrangler recently after it came back from a body shop after an accident. It was however only apparent after or during rain, so it may not be the same problem you're having.
Sent from my SCH-I545 using Tapatalk 4 Beta
B
BobbyB
Magnum V8 5.2L
I just bought the truck last week for $800. It looks like its been sitting for a while though, maybe that clogged it up. Has some body damage to the middle/rear passenger side but nowhere close to where the tube may be located
B
BobbyB
Magnum V8 5.2L
Thanks for the replies guys, I'll get on it as soon as ill be wearing something dirty enough to be under the truck
BUCKYBEAVERENATOR
fresno, ca
diesel 5.9 12 valve crossover
sounds like a plugged heater core to me, mine sounds the same way, im just too lazy to rip the dash apart, lol.
Turkey_Lurker99
5.9 Magnum
Better late then never. I'm new here and this is an issue im having so all input is appreciated. My truck sits a lot mostly driven during foul weather and I here it all the time.
Merc225hp
NA
truck
gas
You have a air bubble in the cooling system, need to burp it and add coolant/antifreeze. Many put the pass side up on a ramp to help burp the system.
Orca
