Is a stage 1 cam worth it on my 15’ Express 5.7?
Tom Hemi 345
Miami FL
I’ve been reading different post in this forum. And am actually new . I was wondering if any one knows the actual gains in HP doing the cam job and is it worth it for a stage 1 or a cam job period ???
What's a stage 1 cam??? Elaborate a little more.
FRP / Moes / MMX / Arrington are outfits you should phone and get their advice,i'd avoid TSP as they don't have a great rep these days. Don't cheap out on the cam and lifters,use OEM lifters.
You'll also need to unlock your PCM before you can tune for the majority of aftermarket cams,and while you're at it,you'll also want to spring for a set of long tube headers (avoid shorties,they're just a waste of money) to compliment the cam
Tom Hemi 345
Tom Hemi 345
Miami FL
So you think I should unlock the PCM tune the truck then how with long tube headers ?? And it’s crazy you said that about TSP lol that’s what I was considering . Am so glad I joined this forum . What tune would you recommend ? I have a 15 ram so the PCM is locked . Can’t really afford to send off my PCM . Any recommendations? Am located in south Florida
Get ahold of Matt Fikac at Moes.
16WhiteQC
Mid Hudson valley, NY
Go on ebay and get a used PCM with the correct part # for your truck, send that one out to be unlocked (this is what I did).
Them pic a tuner / software (diablo vs. HP), Hemi Fever, Jay Greene, Flyin Ryan, etc.
2 of these guy have cams available that I know of.
To get the most our of a cam you should be looking at LT headers so the truck can breath right with the new cam.
Last thing, depedning on the cam you may need a different torque converter as well.
You are looking at approx. $5,000 to do it right, not including a new converter.
Tom Hemi 345
Tom Hemi 345
Miami FL
That doesn’t sound like a bad idea in regards of purchasing a PCM online . Thanks brother
NCRaineman
NC
2019 1500 Classic
You MUST tune with any major mods to these trucks. Even a mild cam will run like crap if you don't tune for it.
Did you get the dreaded lifter failure or are you just going for a performance upgrade? If you haven't replaced the stock lifters and are doing a cam now would be a good time to do it... and the water pump too while you are in there.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
Stage 1 cams are considered OEM+. Basically barely more aggressive than stock. You don't need to tune with one. So I'm not sure what you are expecting from it.
What are your goals? Probably best to start with an unlocked ECU and tuner.
Tom Hemi 345
Tom Hemi 345
Miami FL
Yeah am definitely looking into unlocking the PCM just debating on what tune am going to get ????
Canadian-Hemi
Ontario, Canada
2016 Shorty (RCSB)
5.7 L
Is it possible to use an unlocked PCM with both brands of tuners on one PCM?
I then plan on adding a small cam (Just want the Lumpy sound I miss). This truck is my summer daily driver and for a 2016 it only has 28k kms or
Also I'd like to push the rpm a couple hundred on shifts, and set the temp for electric fan to 190°.
