TSP Lifters? I had a TSP kit installed in my Ram stage 1, and it’s noisy up top. Any thoughts?
Scomer412
Royse city
Had a kit for stage 1 to install in my 2011 RAM by a shop out of Dallas called HPP racing. They didn’t use the mopar lifters, just the ones the came in the kit. I asked Rick at tapped performance look at it and make sure it’s in good runner order and if so to get me a tune because HPP did a bad job on the tune. Well Rick and Jerry are total garbage. My truck is way slower the stock, sounds like it’s missing. They tuned it with a bad coin and active runner codes, lt was like 8 codes that were perm stored.
Anyways, are the TSP lifters any good, or am I gonna have to tear this down again and get mopar?
I’m so mad at HPP racing. DONT BRING A MOPAR THERE. Will these TSP lifter last, or will it chew the stage 1 cam up?
Also I heard the .582 lift is too much for the 5.7 on a stock converter. I guess this is what happens when you listen to a “performace shop” that has no idea what they are doing.
Thoughts on lifters, will they last, are they mopar in the new kits?
Thanks
Snoopy
NE Ga
Man I would think you need to start over with a shop that specializes in Hemi’s. I would at least put Mopar Lifters in it when you do.
hyperlyteman1
California
The problem is this cam requires non-mds lifters, otherwise I would definitely go mopar.
Lowrider357
