Is my garage big enough
jeepinjk
08 jeep jk
Easy question. I am looking at a 09 crewcab 4x4. I have 20ft 3inches available from the back of garage to my door sensors. Will it fit?
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Barely, within about a foot.
emjohn4
I have a '12 CC sport. Fits with about 2" left at both the front and rear, in my 19'6" garage.
I have a 7' door, and it fits fine.
I back in so I can use the camera to get it parked right.
JohnnyDollar
Texas Hill Country
It looks like it will probably fit, but it is probably going to be a tight squeeze.
According to Edmunds data that truck is 19ft long.
If it has a class IV hitch and a ball, that is going to add a few inches.
1' sounds like a lot, but you figure 6" in the front and 6" in the back if the truck is parked perfectly straight. Not a lot of room for error.
I have about the same clearance in my garage and our 2012 Quadcab w/6'4" bed and hitch is a very tight squeeze. (Our truck specs about 1" longer than yours + the ball hitch adds a little)
I recommend having the backup camera. I back ours into the garage and it helps - a lot.
J
jeepinjk
08 jeep jk
I have a 80 inch height on the garage. It should fit in there nicely
Sharp Charge
Brunswick Oh.
I've got to pull all the way to the wall to fit my 11 crew in the garage. I'd have to go measure to see what the dimension is. I can not leave my hitch in the receiver or it will block the door. I had to put a board on the drywall to keep my tow hooks from beating it up too bad.
J
jeepinjk
08 jeep jk
It has your standard hitch. So its removable. And i figured i.might have to protect the wall somehow
J
jeepinjk
08 jeep jk
Lol. Naw i just like keeping things in good condition. Especially items like a house.
Just playin, so did you buy it?
fivehead1
I had to take the bottom bracket off my garage door, or it would hit my front bumper. I literally have 2" to spare to fit my truck in the garage. I have dirt colored ram stamps on my drywall from the hitch cover.
Sent from my SM-T210 using Tapatalk
J
jeepinjk
08 jeep jk
I havent bought it yet. Just checking my options.
dmclone
Iowa
I have a 3 car garage and I have to pull in at an angle for my truck to fit.
emjohn4
When I bought my truck, I made the salesman let me take it home to confirm it would fit in my garage.
I didn't want to spend nearly $40k and have an "oops" moment when I got home.
You can do the same with your salesman. It's just called an 'extended test drive' and he just had to fill out a form documenting the mileage.
audio1der
Airdrie, Alberta
^ Good idea.
I had to tear out the landing w/steps to the house inside the garage, and replace it with 2 simple steps but its worth it for the security and environmental protection.
There are laser pointers, parking traffic lights, tennis ball hanging from the ceiling or just lining up your mirror(s) with something on the wall to get it in just right. Lots of options.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
My old garage my 09 crew for with 3 or 4 ft to spare. At the new place which is actually older no dice I have to park outside :( lame
$miley
JustinRam1500
