I installed the OEM overhead console, just lights, in my 2018 2500 Tradesman. Fairly straightforward, but you will need a wiring harness and Mike at M²Mods can supply it and the technical help to get it all wired up. I actually had to run a wire across my truck to get the lights working properly. More than likely the install will not be just a plug in activity but isn't difficult. Other than not having the anticipated door-switched wire where it should have been, it took me about 45 minutes to do it all. Good luck.
Thanks
No kidding on the wiring
I added a push button dome light to the back of the truck, was a royal pain to hook up
(The point was to have the kids in the back seat be able to turn the light on or off on thier own)
First time I hooked it up (pulling a keyed hot from the front) something funny happened
If the switch was off, the light worked as expected, but when the dome light was off, and the kids pressed the switch BOTH dome light would come up
Great fun
It turned out the factory hot was acting as a ground when I turned my self ran hot on
Nothing a little one way resistor couldn't stop
