Just bought a 2nd gen. Need help!
Ccsred
North Georgia
I just bought a 1999 ram 1500 from work. It's a 2wd ext cab. My question is the 4x4 light comes on dash but it's a 2wd...and I'm positive it's not a 4x4 lol. Any thoughts on what may be goin on? Thanks
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Short in the wiring... Check for a short to grey wire... Under the hood it could be black/grey...
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Maybe it wants to be upgrade to a 4x4?
Yeah i would guess a short some where
ramhunter9
P-Star Jeep Wrangler
Wow ,,, subscribed !
EJM05
Somers, CT
440 Big Block
mines a 4x4 and wants to be a 2wd
Ccsred
Ccsred
North Georgia
Thanks guys I'm gona check the wiring like y'all said and I'll let you know what I figure out.
V-10 RAM
Lee Vining CA
v-10
Are you sure that someone plugged in a light from some other place. Are you missing a light close by?
txbass06
NE Texas
5.9 Magnum
Does it come on when you start the truck and stay on or does it turn off after a few seconds?
Sent from my iPhone 4 using Tapatalk
Ccsred
Ccsred
North Georgia
It stays on all the time. It might be plugged into the wrong spot in the dash that's a good possibility. My work bought it new so there is no telling who worked on it or what has been done over the years. I know the transmission was replaced not long ago. I got it for pretty much nothin so I figure it's worth fiddlin with to use as a work truck.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Hmmmm that is interesting. IIRC on the cluster there isn't a way to cross bulbs. The bulbs are part of the cluster board. So unless there is a wire crossed prior to the cluster I don't think it will be a missplaced bulb. But I could be incorrect. Not sure how the older clusters are. But that is an interesting problem. Didn't know they even had the wiring for that system in a 2wd.
rambob
LA/MS
318 5.2l
found this, might be related...
SUBJECT:
"Service 4WD" Lamp Illuminated On 4X2 Vehicles
OVERVIEW:
This bulletin involves installing a revised HVAC control assembly.
MODELS:
2001 (AN) Dakota
2001 (DN) Durango
NOTE: THIS BULLETIN APPLIES TO 4X2 VEHICLES BUILT BEFORE
OCTOBER 13, 2000 (MDH 1013XX).
SYMPTOM/CONDITION:
The “Service 4WD” lamp is illuminated even though the truck is not a 4X4 vehicle.
DIAGNOSIS:
Start the engine. Once the instrument cluster bulb check has been completed,
verify that the “Service 4WD” lamp is illuminated. If the “Service 4WD” lamp
is illuminated, perform the Repair Procedure.
08-032-00 REV. A -2-
PARTS REQUIRED:
Qty. Part No. Description
AR (1) 55055904AE Assembly, HVAC Control, Durango With
Rear Heat And A/C
AR (1) 55055907AE Assembly, HVAC Control, Durango Without
Rear Heat And A/C
AR (1) 55055905AF Assembly, HVAC Control, Dakota, With A/C And
Rear Window Defogger
AR (1) 55056408AE Assembly, HVAC Control, Dakota, With A/C,
Without Rear Window Defogger
AR (1) 55055906AF Assembly, HVAC Control, Dakota, Without A/C,
With Rear Window Defogger
AR (1) 55056409AE Assembly, HVAC Control, Dakota, Without A/C,
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
7th line down....
