Key Fob 2014 Bighorn NO key start?
rsdata
N Ky
2014 BigHorn 1500 8spd 4X4
OK... so I got this RAM last August. So far I have just passed 40K miles total, but I have only put 6K on her. So I was reading on here about key fobs. When I bought used from a dealer, I insisted on an additional fob as part of the deal as it only came with one. So now I have played with the functions of the fob... I have remote start, and I can use the removable key to open the door. However I can insert the key into the dash start button, and the dash lights start to function, and it will turn, (have to push it in and turn) but it will not start the RAM.
What good would giving the key to a valet be if the key does not start the RAM?
I have taken out one of the keys and had a locksmith make a duplicate... it is a full size key. It does unlock the door. I hid that key so if I should lose my keys I will not be locked out, but I still cannot start the RAM with it. I have taken the second fob and put it under the rear seat so if I do loose my first fob, I can find the hidden key, let myself in and retrieve the second fob.
What do YOU DO in a similar situation?
Jeffnc84
Apex N.C.
2015 ram
You give the valet the fob, and you lock the glove box with the key, keep the key with you
Sent from my SM-N910V using Tapatalk
rsdata
rsdata
N Ky
So having a key is worthless for starting the RAM???
SilverRam11
4.7 V8
You can buy a special key that will start it as well. It is a key that is cut to the lock, and the handle of the key has the chip and the little notch that a fob has to start it. Find a locksmith to sell you one and cut/program it.
Demon-HeMi
Houston
2003, 2003, 2008, & 2013
(2) 5.7 HEMI, 3.7, & 3.6
wait, we can get a normal key for our trucks that have keyfobs????
SilverRam11
4.7 V8
No. It's just a key that can open the door and start the truck.
Murphy Slaw
Southern Illinois
2016 Bighorn 4X4 Crew
A key that will open the door and start the truck.
Doesn't feel like a banana in your pocket, doesn't "PANIC" if you lean forward in your Lazyboy, doesn't start your truck accidently.
What a novel freaking idea.
