sparky300
- Oct 21, 2017
- 19
- 6
- 2011
- 5.7 Hemi
I've finally finished installing a RAM1500-230 onboard air system with triple train horns from Kleinn Air Horns on my 2011 Ram 1500 SLT so I thought I'd share it with you. It's a vehicle specific kit as it includes all hardware, brackets, connectors, wire, relays and detailed instructions. The whole kit mounts to the front frame just behind the bumper and is virtually unnoticeable. An accessory kit that includes a 1/4" quick disconnect and 20' coiled air hose and chuck with bag was also included.
Overall, a very well engineered system and the triple horns are loud as hell. I chose to keep the stock horn and run a separate circuit with a piggyback fuseholder from circuit M33 to power both the compressor relay and horn solenoid. The compressor is controlled via the 30A relay and a pressure switch that is only powered when M33 is energized with the ignition on.
I have no affiliation or interest with Kleinn Air Horns.
Compressor mounted
Compressor and tank assembled
30A Fuse and relay installed
Horns installed
Compressor and tank installed
Compressor mounted
Horns installed
