LED 3rd brake light resistor question
2010 Infantry Vet
Butler pennsylvania
I got my (2) 6 ohm 50 watt resistors today. The plug has 4 wires. I got these because my white led cargo lights in the 3rd brake light stay dimly lit. I connected my LED 3rd brake light to my factory plug. One by one cut the wires to see which one was what. I found when i cut red wire, brake light went off. But i had to cut yellow and white wires to turn off white led cargo lights. So i installed a 6 ohm 50 watt resister on the yellow and white wires. Low and behold, when i shut the truck off, white LED lights are still dimly lit. Someone please help.
Black-Im assuming is ground
Yellow
White
Red-Brake light
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
Just grab canbus led bulbs and call it a day. They have resistors built in, problem solved.
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
Which LED 3rd brake light are you using?
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
Viogi VX it says is the brand.
I bought the resistors from VIPMoto and they said to connect one resister between the black ground and power wire. Does this sound right?
I tried installing a resistor inline on the yellow wire, and one on the white wire. Didnt work. light continued to stay on.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
UPDATE- Connected one side of resistor to positive wire, and other side of resistor to negative wire. Light stays off now and eorks the way it should. But the resistor gets so hot if you touch it, it will burn your finger. Is that normal for the resistor to get that hot???
JB1
Houston, Texas
does that use those chinese CREE LED's?
CuylerTech
NH
6.7L
With resistance comes heat, I would recommend using a heavy duty high heat epoxy to mount it by the 3rd brake light as if it dangles it will burn through the headliner.
2010 Infantry Vet
2010 Infantry Vet
Butler pennsylvania
I ended up mounting it to the sheetmetal so its away from all of the wires and plastic housing. Still cant beleieve how hot it gets.
Ftank
