LED bed lighting in 2015?
SeventyGTX
The 2015 Limited I picked up a few days ago has the holes for LED bed lighting. I did a net search for them, and found kits for the 16's and 17's but not a '15. My bed has the factory holes, but I couldn't find any plugs underneath, although its getting late and I haven't looked real hard and it's tough looking in there with the air bag stuff. My '16 2500 had them and I really liked them.
Does anyone know if the kit for the '16's will work on my '15? It is Mopar part number 82214870AB. Thanks for any help, you guys rock!
SeventyGTX
SeventyGTX
Well I ordered a set even though my truck doesn't appear to have the plugs for them but does have the holes in the bed. I checked some Amazon reviews and a couple of guys said to just tap into the white/brown cargo light wire under the drivers side sill panel. Sounds like it may work out better since I won't have to take it to the dealer and cross my fingers they can progam them.
Srt-cummins
Dayton, Texas
This will work, as I did the same to my truck right after buying it. From what I’ve gathered the late 15s have to provisions in the bed but not the wiring. The kit I bought had the wiring to run All the way to one of the modules under the dash but our trucks do not a pin where your told to plug it in. I just taped the cargo wire under the door sill of the driver rear. The color you mentioned sounded correct.
JustinRam1500
