Left turn signal turning on high beams
PGH_Mac
Pittsburgh PA
Cummins
2023 3500 Cummins. My left turn signal turns my high beams on. I am not pushing the handle in any direction but straight down. Has anyone heard of this being an issue or know of a DIY fix? If there is already a thread for this, I apologize. Still learning to navigate the page.
Administrator
With the truck being a '23, the DIY fix is take it to the dealership.
Possible it's the multifunction switch in the steering column but it could also be a problem with the BCM.
PGH_Mac
PGH_Mac
Pittsburgh PA
Cummins
Thank you, I figured that but with it being a work truck I was hoping it was something I wouldn’t have to take it in for. I appreciate your time.
TestPilot57
Vermont
I have no dog in this hunt, but just curious - does that mean the Left Turn Signal does not work? Or does it trigger both LTS and HiBeam?
RamCares
n/a
n/a
Hey there,
If you'd like some assistance with this, we'd be happy to get you in touch with one of our case specialist. They will be able to get you some help with repairing your vehicle. Please reach out to us via direct messaging if you're interested.
Callie
Ram Cares
06 Dodge
Forest Grove, Oregon
6.7L CTD
Day time, night time, are you moving i.e turning when it happens or sitting still, are your head lights set to Auto?
AOE33
Clearwater
Did you figure this out? The dealer can get my truck fixed and it is super annoying.
HOTSHOTTER
HOUSTON
CUMMINS 6.7
HI, I HAVE 2023 TRADESMAN. SAME THING. JUST STARTED DOING THIS, 1,050 MILES. ORDERED FROM FACTORY. WHEN YOU HIT LEFT TURN SIGNAL HIGH BEAMS COME ON, NO MATTER THE SETTING. I ALSO DONT HAVE TIME TO LEAVE IT AT THE DEALER. IS THERE A WAY TO DISABLE THE HIGH BEAMS? IM THING IM GOING TO HAVE TO REMOVE THE BULBS. OR PULL A FUSE? IF ITS IN THE COMPUTER THERE IS NOT GOING TO BE A WAY TO STOP IT WITH OUT AN ECM FLASH. ANY IDEAS?
AOE33
Clearwater
I can tell you if you turn your high beams on it will function properly. I think it’s the multifunction lever but the dealer won’t replace it as they do not have a 100% assurance that is it.
Twasnok
Diesel
Hey there,
Callie
Ram Cares
My 2023 2500 doing same thing? What was the remedy? Thank you
HOTSHOTTER
HOUSTON
CUMMINS 6.7
OK, YES. IF YOU PUSH THE LEVER FORWARD ALL THE WAY WITH HEADLIGHTS OFF, OR WITH RUNNING LIGHT ON. IT WILL STOP ENGAGING WHEN YOU SIGNAL.
BUT WITH HEADLIGHTS ON, BRIGHTS ENGAGE WHEN YOU SIGNAL LEFT.
SO, WHEN YOU SIGNAL LEFT WITH HEADLIGHTS ON YOU CAN PUSH FORWARD THE LEVER AND IT WITH STOP THE BRIGHTS. BUT ONCE YOU STOP LEFT SIGNAL YOU HAVE TO PULL THE LEVER BACK CAUSE BRIGHTS GET TRIGGERED AGAIN.
SO, SOMETHING IS CROSS WIRED BETWEEN HEADLIGHTS, AND LEFT TURN SIGNAL.
CONCLUSION, EITHER IN HARDWARE WIRING IN THE LEVER ON STEERING WHEEL, TO FUSE, TO INDIVIDUAL LIGHTS, or COMPUTER PROGRAMED ISSUE.
THANKS AOE33 FOR CONFIRMATION
I WILL TRY TO WORK ON A SOLUTION
RamCares
n/a
n/a
Hi there,
Do you plan to work with your Ram dealer to get a diagnosis? If so, we'd love to offer an extra layer of support at that time if needed. Please send us a private message!
Lex
Ram Cares
Dodge 1500 4X4
Rochester, NY
Hi there,
Lex
Ram Cares
Sounds like it's time to let RamCares get involved!!!
Ricizi
Kansas City
Cummins 6.7
Mine is doing the same thing, if I’m sitting at an intersection the high beams will turn off after about 5 seconds while the turn signal still functions. It also seems to depend on the lighting outside because there are instances where the high beams don’t come on with the left turn signal.
RamCares
n/a
n/a
Hi ricizi,
We are sorry to hear you are also running into this concern. Do you plan to get an appointment in place with your Ram dealer for diagnosis? If so, we are available via private message and would be glad to get you in touch with one of our specialists for some additional support at that time.
Lex
Ram Cares
AOE33
Clearwater
Any luck on a solution, my dealer is still stumped?
BossHogg
Oakland Township, Michigan
6.7L Cummins
Hi ricizi,
Lex
Ram Cares
With all due respect and I (as others likely do) appreciate your continued offers to help RAM owners but I think you should go to a RAM dealership's service department for the experience and discover just how incompetent and their display of unwillingness to help. The BS that comes out of the mouth of the service advisor is beyond amazing, and for them to think we are that ignorant to buy into their nonsense is brazen and at the same time infuriating.
I know not all dealerships are like this but the vast majority are. I've had experiences with five RAM dealers before I found a decent one and even they get a little insulting.
It takes weeks to get an appointment. Once you get in you hear they can't duplicate the customer's concern or if they do, no parts to repair. Tell you they are not paid to diagnose the issue just find it. If you record the issue and show them, they tell you they need to see it happen to fix it. Well, vehicles and issues don't always cooperate.
Bb23EP
I bought a 2023 2500 Big Horn 6.7 this week. Drove it at night for the first time tonight and same thing. Signaling for a left turn, HBs come on. Stop with left signal on, complete turn and HBs come on. 300 miles on the truck
Bb23EP
Hi ricizi,
Lex
Ram Cares
Dodge 1500 4X4
Rochester, NY
It has to be a defective turn signal switch lever, the only problem the steering wheel has to be removed to replace it!!!
