Leveling 04 Ram
Tinybaum
Maryland
So there is a kit for that? I was going to adjust the torsion bars some, but wasnt sure as to how high I could go. I see where others change shocks when doing that, is that needed? I just put new shocks on recently and done really want to replace, but I want the truck level.
So basically:
What are the advantages to the kit vs torsion bars?
What issues maybe be caused by either?
And do I have to change shocks?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Here is a write up I did awhile back. I ran keys in my 04 when it was leveled, 05 has it just cranked. You can get away with 2" on the keys cranked and shocks are up to you. My 04 with keys needed shocks because it would max out on a bump, the 05 is fine with the stockers.
http://www.ramforum.com/f76/leveling-02-05-4x4-9788/
T
Tinybaum
Maryland
Thank you...Going to give it a read over right now.
T
Tinybaum
Maryland
I would probably just crank it. I dont want to change out the shocks as I just put them on.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Soak the treads and go a few cranks each time. Make sure you measure before and after, also "bounce" the front for the bars to settle.
