Leveling kit ram 2500
Tyler Bailey
Ct
Cummins 6.7
I have a 2015 ram 2500, 6.7 Cummins, with the factory air ride in the rear. I am wondering if any one has any info on leveling the truck?
Derek Powers
Do a spacer in the front. Easy, cheap, maintain your factory axle weight rating and ride
mtnrider
Georgia
Carli, Thuren, Bilstein are all good choices (new springs, not spacers). The air ride system just requires a sensor relocation bracket in the back to make it work properly with the level kit.
olyelr
Kewadin MI
Any 2500 with air suspension in the back, that I have seen anyway, looked pretty level in stock form.
They appear to be the same height in the front as non air suspension trucks, but lower in the back (kind of like a reverse level).
RedneckHippy
Washington
2019 Ram 3500 Tradesman
6.4 Hemi w/ MDS
My opinion, I’ve done Carli and Thuren in the past, they are top of the line and awesome, but overbuilt for most people’s uses. This time I just put a zone leveling kit on mine, it was a hundred bucks, you can always spring for longer shocks if you so please, but I used a shock extension that was 20 bucks on amazon. Once I wear out those factory shocks, I will get the extended ones and swap it out at that time. I drive probably 80% on road and D809AEBC-15AE-4103-A033-5B803DFC9379.jpeg 20% Forrest service fire roads. If you plan on doing real off-roading where you need articulation and suspension components that are built to withstand a true beating then go Carli or thuren all the way, but if you are fine with factory ride and equivalent if not better than factory componentry go cheaper. I’m talking leveling kits here, if you want a lift kit that is a whole different story and I would say Carli and Thuren regardless.
MADDOG
Out Exploring Arizona
I leveled my 2017 2500 with a Tuff Country # 32909 2" spacer kit with shock relocation bracket.
I've used this particular kit, or earlier versions, on three 2500 Ram trucks and had no issues with any of them.
My 2017 does not have rear self leveling air. My 2014 did have it. Looked fine and level to me. My 2007 did not have air either and looked great.
Bldrinker
My opinion, I’ve done Carli and Thuren in the past, they are top of the line and awesome, but overbuilt for most people’s uses. This time I just put a zone leveling kit on mine, it was a hundred bucks, you can always spring for longer shocks if you so please, but I used a shock extension that was 20 bucks on amazon. Once I wear out those factory shocks, I will get the extended ones and swap it out at that time. I drive probably 80% on road and View attachment 200328 20% Forrest service fire roads. If you plan on doing real off-roading where you need articulation and suspension components that are built to withstand a true beating then go Carli or thuren all the way, but if you are fine with factory ride and equivalent if not better than factory componentry go cheaper. I’m talking leveling kits here, if you want a lift kit that is a whole different story and I would say Carli and Thuren regardless.
what size leveling kit and what size tires do you have?
RedneckHippy
Washington
6.4 Hemi w/ MDS
It is a 2 inch leveling kit, still running stock tires (33s) until they are used up. Plan to do 305/70R18 or 315/70R18 (little bigger than a 35) at that point.
