I was under the understanding that "Life-Time" is not the life of a Human, or even the lifetime of ownership. Lifetime is defined usable life span of the truck. Not sure on what usable life span is though. But I'd be surprised if its greater then 10yr.
And I'm sure there are many "loop Holes" that will cause covered repairs to cost way more then the deductible.
WHEN PLAN COVERAGE STARTS AND ENDS: Plan coverage begins on the date you purchased the Plan for: (i) a Vehicle component not covered by the manufacturer’s warranty; (ii) Trip Interruption; (iii) Car Rental in respect to covered repairs when a replacement vehicle is not otherwise provided; and (iv) Taxi Reimbursement. Plan coverage begins on the date the manufacturer’s warranty ends for: (i) any Vehicle component covered under the manufacturer’s warranty; and (ii) Roadside Assistance.
This Plan offers mechanical coverage as specified to the named purchaser or retail lessee of the vehicle only, for the lifetime of that purchaser or retail lessee. The Plan ends upon the death of that purchaser or retail lessee or upon the transfer or sale of the vehicle. The Plan ends even if the transfer occurs by operation of law, such as to a lienholder, family member through succession, or successor business.
COVERAGE UNDER THE PLAN: WHAT IS COVERED? The Plan will pay the total cost (parts and labor) less a deductible per visit, to correct any of the following mechanical failures, caused by a defect in materials or workmanship of a covered component and are not covered by the vehicle’s factory warranty. The only exceptions are those listed under “What is not covered by the Plan”.
THE PLAN WILL NOT COVER, OR APPLY TO LOSS OR EXPENSE RESULTING FROM:
• Repairs or replacement of any component covered by any of the Vehicle manufacturer warranties, Certified Warranty, part manufacturer warranties or recall policies; roadside assistance, loaner vehicles or other services which are eligible to be covered by the Vehicle’s manufacturer warranty or marketing programs;
• Repairs required as a result of other than a manufacturing defect (such as a design defect or normal wear);
• Repair or replacement of any covered component when it has been determined that the condition existed prior to
purchasing the Plan;
• Plan benefits where the Vehicle odometer reading has been stopped or altered and/or the Vehicle’s actual mileage
cannot be readily determined;
• Brake pads, shoes, rotors and drums are not covered at any time (regardless of cause of failure);
• Reimbursement of services/benefits that exceed the total number of services/allowance included in Plan Coverage;
• Battery and cables, any battery for a component, spark plugs and wires, lights (bulb, sealed beams, lenses),
suspension alignment, wheel balancing, wiper blades, exhaust system components, heat shields and exhaust hangers;
throttle body cleaning; evaporator deodorizing; carbon cleaning;
• Plan benefits necessary as a result of (a) failure to properly care for or maintain the Vehicle; (b) fire, accident, abuse,
vandalism, negligence or Act of God including but not limited to the Vehicle rendered inoperable due to snow, ice or flood; (c) failure to properly operate the Vehicle; (d) Vehicles that have been used or are being used for competitive speed events such as races or acceleration trials; (e) pulling a trailer that exceeds the rated capacity of the Vehicle or failure to adhere to the requirements for vehicles used to pull a trailer as outlined in the owner manual supplied by the manufacturer; (f) tampering with the emission system or with any parts that could affect that system; (g) use of dirty fluids, or fuels, refrigerants or other fluids which are not recommended by the manufacturer; (h) failure due to fluid contamination or sludge; (i) modifications not approved or recommended by the manufacturer; (j) overloading rated payload capacity of the Vehicle; (k) damage incurred by off-road usage;
• Plan service obtained from other than a Dealer unless authorization is first received from us. FCA US Vehicles must return to a FCA US LLC Dealer for Plan covered repairs; (Dealers cannot authorize repairs.)
• Repairs required as a result of use of other than the Vehicle manufacturer’s parts during the term of the Plan, unless authorized by us;
• Repairs to a covered component caused by the failure of a non-covered component and/or an aftermarket installation not performed by a Dealer, or any outside installation of "salvage or junk" components in conjunction with an insurance or damage claim. All part installations to satisfy such claims must be with new or factory authorized remanufactured components and parts;
• Bodily injury or property damage arising or allegedly arising out of a defect in the design, manufacturer, materials or workmanship of a covered component;
• Any fines, fees or taxes which are associated with impound towing as a result of actual or alleged violation of any laws or regulations;
• Plan benefits to Vehicles operated outside of the United States, Canada, Guam, Puerto Rico and Mexico;
• Plan benefits to Vehicles registered outside of the United States, Guam and Puerto Rico;
• Exterior - tires; body sheet metal; glass; plastic lenses; paint; bright metal; bumpers; side-view mirrors (glass/
housing); wheel covers; steel wheels; aluminum wheels; rusted or frozen rims; weather strips; rust; water leaks; restricted drain tubes; wind noises; all outer body panels; spoilers; plastic and fiberglass body parts; vinyl tops; convertible top fabric; repairs or damage caused by environmental factors such as acid rain, tree sap, salt or ocean spray;
• Interior - trim; carpet; upholstery; dash pad; door and window handles; knobs; buttons; moldings; arm rests and head liner; cargo cover;
• Mechanical - manual clutch assembly; repairs to snow plows, winches and trailer hitches regardless of their installation; damage to flywheel as a result of clutch failure;
• Shop supplies, waste disposal fees and materials;
• Repairs to any Vehicle where the title has become branded or the Vehicle has become restricted by the manufacturer
after the purchase of the Plan;
• Maintenance services specified in the owner’s manual and the parts used in connection with such services;
not performed by an authorized Dealer;
• Repairs or replacement to components covered by the Hybrid System Limited Warranty (refer to Warranty booklet for
details);
• Portable Units including but not limited to - headphones; I-Pods; GPS units; DVD players; laptop computers; cellular
phones; any hand-held device; Navigation DVD;
• Repair or replacement of Performance parts, Performance enhancing parts;
• Any economic loss of any kind, including but not limited to rental car expenses, consequential damages, incidental
damages, or other losses that relate in any manner to your use or loss of use of the Covered Vehicle.
