Lift for fitting hummer rims/tires
jonnymoon5
5.9 Magnum
Hey all,
I'm looking for what amount of lift i would need to fit 37x12.5r16.5 humvee tires on my 02 ram 2500? I have a 2" leveling kit on it and it looks like it would fit, but I wouldn't want to buy the tires without them fitting. I'd rather stay away from body lifts, but I don't want to go all out with long arms.
Thanks
-Jm5
rowdyram
magnum 5.9
4.5-5 inch I have 2500 no lift or level and clear 36x11.5r16s bearly but if I flex it real hard it will rub.
rammanriley20
iowa
1999 Ram 1500
5.9 Mag
id say youd be safe with anywhere over a 4in lift. maybe less if you trim
DodgeHimRamHer
Spotswood NJ
5.9 Magnum
I couldn't help but notice it says "rims" too, were you planning on using the run flats? Only reason i ask is because those wheels aren't going to have a lot of offset so you might rub more than you think.
Orca
