Looking at transmission options behind 360
Discussion in 'General Discussions' started by DRTDEVL, Nov 20, 2016.
  1. DRTDEVL
    DRTDEVL Junior Member
    Nov 20, 2016
    Ram Year:
    1980
    Engine:
    360
    I have a 1980 Sportsman van chassis (1981 completion) Winnebago "Minnie Winnie" 20RG RV. It has a 360 and a 727 driving it, but it gets HORRIBLE mileage. I have contemplated engine swaps (4BT, 6BT), but honestly, they won't be cost-effective for the little driving the RV sees. I'd probably drive it more if it got more than the 5-6 mpg it does now... so the thoughts turned to the transmission.
    The 727 is obviously a non-lockup, non-OD 3-speed. I am looking for the easiest swap to an OD trans, preferably with a lockup convertor. I keep coming back to the 47RH from the 1994-1996 2500/3500 Rams with a TC lockup switch, but I am wondering if there are any other viable and cost-effective options.
  2. reek
    reek Senior Member
    926
    343
    Nov 23, 2014
    Sacramento
    Ram Year:
    2015 RAM 2500 CC 4x4
    Engine:
    I'm currently working on the same issue. the easiest swap would be an a518 or 46rH. should be on 90-95 vans, 92-95 Dakota 318s, 90-95 ram 150 V8s and ramchargers of the same era. if you go to a pick and pull, grab the shift linkage and if you can the shifter, they're just a tad different. BTW, your 727 should be a lock up. I think only pre78 didn't have lock ups. if it matters, the lock up version have a smooth tail end of the input shaft and the non locks are splined all the way down.
    hope that helps some.
  3. ric3xrt
    ric3xrt Member
    48
    40
    11
    Nov 26, 2016
    Trumbauersville Pa
    Ram Year:
    Engine:
    7.0
    on the big of a ride you didn't get the lock up convertor.
    like Reek said your best bet is the 518 or the 46rh , I think the 518 would be a better choice.
  4. DesertWagon
    DesertWagon Member
    41
    94
    22
    Oct 23, 2016
    Ram Year:
    2008
    Engine:
    The 518 is a 46/47/48re. The inter parts are interchangeable. Just different bellhousings for gas or diesel.
  5. crazzywolfie
    crazzywolfie Senior Member
    14,102
    2,147
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    hahahaha. a 46RH and 518 are the exact same tramissions. just different names for them kind of like you could call the older transmissions a 727 or a 36RH
Share This Page
