Loose oil dipstick tube
robby5323
East Texas
2014 Single Cab
So, I purchased myself a used 2014. 5.7 six speed with the 3.55 rear. It has a set of the JBA longtubes installed. I reached down to check the oil yesterday and noticed the dipstick tube is loose from side to side. After a little research this seems to be a source of problems when using the headers. Any creative fixes to help secure the dipstick tube?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Is the tube bolted down? There should be an upper bolt that secures to the top front bolt of the header, and then a 2nd bolt down where the tube goes into the block.
R
robby5323
East Texas
2014 Single Cab
Thanks, I will have to check. I guess I may have to pull the wheel well liner to even get to it... Luckily it's not leaking at this point.
R
robby5323
East Texas
2014 Single Cab
With the header install, you have to bend the dipstick tube a little. The culprit was a broken spot weld on the tube down by the pan and no bolt at the top mounting location. You have to bend the dipstick tube to clear the headers and this was the result.
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
It will stay secure with just the top bolt in place. I have installed many sets of longtubes on these trucks. Ideally you do want both bolts secure, but it will work fine with just the upper.
Orca
