took a few to remove the screen but here goes.Would it be possible to see a closeup of the underside of the PCB, at the area the connectors are soldered in?
You would think they would update their web page like the others.Contacted both and none to be had , unavailable. Thanks for the try.
Or, test the pins on the circuit board to try to reverse engineer it. I can see 2 that have traces connected to them. If I had it under the glass and some good light, could probably be done fairly easily.
Also, since it is an OEM discontinued part Holley should probably release the engineering drawings for it.
This drawing may shed some light in this quest
I found it interesting, as the pinout from the OBDII cable connected to the canbus. I was just wondering if the Diablo used the same wiring logic, just connected to the 16 pin connector.That looks interesting but I have to wonder if the DB9 connector is for diagnostics of the tuner.
All of the online pics I've seen show the OBDII interface connected to a 16 pin connector.
Then again, it might be worth building the DB9 version as a test. Does that drawing have any references to the Diablo T1000?
It would be great if they would release a pin-out drawing but I believe Vern asked for the cable and was offered a 25% discount on the latest model.
Vern, you asked for a cable, but did you ask for a pin-out drawing?
That might be worth the effort.
Well, here is Holley's response:I contacted both Diablo and Holley , neither was able to provide that to me . Maybe your inquiry will reach a more knowledgeable associate . Thanks for the help.
