Lower ball joints 03 4x4
AnEngineer
I was reading in my Haynes manual about doing the lower ball joint on my 03 4x4 1500. It claims that you have to remove the lower control arm completely which involves taking the torsion bar out and a whole lot additional crap that I would like to avoid. Why can't I remove the knuckle and strut assembly and leave the lower arm on there and press the broken ball joint out like on the 4x2 model? Am I missing something?
Hemi Ram
South Shore, MA
2006 Ram 1500 Quad Cab 4X4
I would just replace the lower control arms. A few bucks more but also will replace the bushings. If you live in the rust belt expect the eccentric bolts that hold the control arm on to be permanently rusted in place.. then just do the ball joint. I bought Moog lower control arms for my 06 for $ 65 each.
Sent directly from my thoughts using tinfoil antennas and a stainless mixing bowl helmet.
