blackbetty14
- Joined
- Oct 23, 2014
- Posts
- 2,703
- Reaction score
- 1,427
- Location
- CT
- Ram Year
- 2024
- Engine
- Hemi 5.7 VVT/Etorque
Decided to get another pioneer 8” shallow sub. I will make a 2nd box for the driver side under the seat and keep the fold flat floor. My question is I don’t want to put a lot of money into the system. I’m happy with the stock upgraded alpine system with the pioneer sub in the stock box on the pass side. But just wanted a smidge more bass.
Here’s what I want to do.
1.) make small box for the minimum .5cuft space.
2.) tap into the stock sub wires for signal, thinking high pass wires into amp.
3.) throw my barely used pioneer 8601 d series mono amp and wire the subs dual 2ohm to a 4 ohm load. The amp puts out 300wrms at 4 ohm which is high (double) of what the sub is rated for.
You guys think that will be a problem? 300wrms too much when the sub is rated for 150wrms? I was using this amp to power a 12” pioneer shallow sub and it worked good. I have a small kicker powersports amp but that only puts out 50wrms. What’s annoying is I have a 12” box and sub for the truck but on my 14 CC I had to use 3/4” spacers and that didn’t have the fold flat door which I would loose. So I don’t want to go that route.
Also you guys think the sub amplified wires will fry the high pass on the amp? I have a scosch LOC but don’t want to worry about remote turn on etc.
