Maximum level on Bilstein 5100 without compromising stock ucas
Gafas
Luanda, Angola
Hi,
I know there's a lot of info about Bilsteins. Sorry if someone already post that.
What I'm currently planning on a budget.
Front Bilstein 5100 2.1 level (with stock uca) that's my concern
Rear all stock with a 1.5 spacer.
Planning later on to install on the rear.
I appreciate your feedback,
Thank you,
Pedro
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Hi,
Thank you,
Pedro
2.1 is fine with stock UCA’s if you send @Nick@GotExhaust a message he can get you set up with the Bilsteins all the way around and Bilstein also makes rear coils that pair perfectly with the 2.1 setting. Spend the few extra dollars and.
Nick@GotExhaust
Preferred Vendor
SC
2.1 is about as high as you want to go on stock UCA's. However if you plan to off road it may pay to upgrade them anyway. For street use the stock ones are fine at that height
Message me if you would like a quote on anything.
dieseldave
Little Suamico
I plan on installing the 5100 s Bilsteins on my 2021 Ram 1500 big horn . No off roading , just want it leveled. Do I have to do anything to the rear end.
G
Gafas
Luanda, Angola
I do a lot of corrugated roads here in Angola - Africa. Ok, I will consider changing them.
Thanks
dc435911
Springfield, IL
Thanks
How high would you like to go on the Bilsteins? If max, 2.8", look at Rough Country Upper Country control arms for 3" lift. They work great and aligning is much more simple.
Nick@GotExhaust
Preferred Vendor
SC
You can leave the rear stock. Some like to do 5100's for the rear shocks along with the 5100's up front but you do not have to do that.
loveracing1988
Clarkston, MI
How much tire clearance do you lose from the stock control arms to the zone control arms?
dieseldave
Little Suamico
NICK, Is April 4th still the E.T.A. for the shipment of the December order of Bilsteins 5100s
Hookedup87
Long Island
If you set your Bilsteins at 2.1 and then use a 1.5” spacer in the back you are going to createh quite a bit of rake if that is what you are trying to do.
I’m going to be setting my 5100’s at 2.8”, with new UCA’s, and installing a 1” Daystar spacer in the rear and hoping to be pretty close to level.
Hookedup87
Long Island
And my prior truck had Bilsteins set at 2.1 for years on stock UCA’s and never had an issue. And that truck had only a slight rake. But that was with no rear spacer. That’s why I’m mentioning with a 1.5” rear spacer your probably going to have at least 1.5” of rake.
Jasfish18
I did eibach springs and on the lowest setting I got about 2in. After about a thousand miles the ball joint was starting to separate, very little but was there was a slight gap. I ordered zone uca but they took forever and due to a time crunch put on the mevotech. It's been about 15000 miles now and they are fine. Still have the zone, but haven't seen the need.
augiedoggy
western NY
3.0 Ecodiesel
This is really starting to suck
Nothing against others but you could have ordered them anytime from amazon without the wait time... These are the ones I bought and used on my 2015... https://www.amazon.com/gp/product/B01LRJ855E/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 bilstien changed the packaging so they are clearencing the shocks still in the old packaging but they are the same. I'm using stock control arms with mine and 2" superlift springs in the rear with the 5100s there as well.
Steve McL
Reno
What kind of one and a half inch rear urethane spacer did you use?
