Melted Battery Terminal
njjeff201
Sparta, NJ
5.7 E Torque Hemi
I hope your new battery works out. But you said next day it wouldn’t start? Longest I got was 9 years out of a Mitsubishi battery (original). Don’t remember whose name was on it but I kept it full. Some batteries claim sealed while you can still pop top off for adding water. Think the newer ones are actually sealed. Good luck!!!
Treburkulosis
Your High End Detailer
Haslet, TX
I would separate that nut on the backside of your terminal, loosen the nut on the post and try and break it loose with a pair of vice grips. You can replace the post itself and then just replace the terminal. That is at least how I would approach it.
njjeff201
Sparta, NJ
5.7 E Torque Hemi
Good idea... they also sell tge red/green felt rings but you have to install those under the cables
njjeff201
Sparta, NJ
5.7 E Torque Hemi
Treburkulosus... replacing the terminal means the entire cable. Breaking the battery post means new battery. Aftermarket battery cable ends are trash!!! Will work temporarily but... I don’t trust em. Will definitely corrode eventually & poor for handling the current
njjeff201
Sparta, NJ
5.7 E Torque Hemi
Nasty corrosion. Did you clean with baking soda & water?? Blow dry?
Treburkulosis
Haslet, TX
I have never had any issues with replacement terminals, but I also live in the south, so no rust issues or corrosion issues. According to auto zone and I wouldn't buy from them, but quick search has replacement post. I have replaced them on other vehicles. Yes in theory replace it with OEM and then a new battery. If the battery is still good why replace it?
https://www.autozone.com/batteries-...V7DizAB2FxwmfEAQYASABEgLvrfD_BwE&gclsrc=aw.ds
You guys should actually read some of the posts,he's got it running again,and has put a new battery in the truck.Everything you guys are suggesting was already suggested awhile ago.
averageguy
Belleville Mi
hemi
It seems alot of people read the first post, skip the 10 pages after that and post a reply.
T Jones
T Jones
Ohio
Just a wire brush. They cleaned up pretty easy. I also used felt washers and sprayed the terminals with a red anti corrosive. It's been starting up with no issues at all since I replaced the old battery with my new AGM, as suggested by everyone who responded.
T Jones
T Jones
Ohio
Lol...
