I am installing the ModifyStreet headlights and have a few questions. Does anyone have a link on how to install them? And if there is no link where do you guys wire the DRL on them? Any advise is appreciated. Thanks.
Wiring is straight forward. The connector with white/blue/black wires connect to your low/high headlight connector. Your turn/park socket will plug into the corresponding 3157 plug. Then the socket gets inserted into the whole like it does on the oem headlights.
As far as the drl wiring. The way it is intend to work is the red wires plug in to the corresponding connections on the headlights. Then you have 2 battery connections and the Grey wire goes to the fuse box to a keyed on fuse.
If you have alphaobd then there is a little more complicated way to get a more oem connection for drl's.
Although there is a lot of information in the modifystreet thread you can find all the information there. Mainly the last 50 post or so
