Moe's Performance NEW 87mm Ported Throttle Body
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
OK guys, we currently have (6) 87mm TB's and (5) 85mm TB's in stock and ready to ship. As always, these will go out same day and tracking will be provided :peace:
09SMOKINHEMI
TEXAS
let's go guys.... let's get these off the shelves....
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Clear some room for the 10 more 87's that will be ready on Monday. No shortage of TB's here :naughty:
UNBROKEN
2012 Ram R/T
Save me one. I have to run out to Tomball late next week to pick up some other parts. I'll meet up with you then.
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
I already had 1 set aside for you. Just shoot me a text or PM when you will be in the area.
Texasez
Dallas tx
Any results from a stock one yet. I have a bone stock 12 with 1600 miles if you need a guinea pig.
dogcar3
2012 Power Wagon
87mm TB on stock Power Wagon
First off, pictures are HERE
Except for this mod, my truck (2012 Power Wagon) is completely stock performance wise. And you have to understand this is a 7k pound truck.
Got home yesterday and found my Moes 87mm throttle body had been delivered. It was securely packaged and also came wrapped in a clear plastic bag, guessing for a moisture barrier.
The install took 12 minutes; from walking out the door to the truck to the time I was walking back in the house. Includes time for taking pictures.
So far I have only driven about 10 miles, half city and half highway. Temperature was around 48 degrees F.
There has been no codes thrown on my truck. On startup there was no difference in idle or warm up characteristics.
Throttle response is slightly better in certain situations (rpm, load etc). Most notably starting from a stop.
As far as power gains, I cannot say for sure. The truck does feel more lively, but that may just be because I was pushing it a little harder trying to get a feeling in the butt dyno. Not sure how readily a 2-3% gain could be felt in a brick on wheels so take it for what it is worth.
All in all, I am satisfied with the new mod. I am sure with more mods this 87mm TB will become more beneficial.
EDIT: I did not do the computer reset after installing. So more gains may be felt as the computer adjusts.
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Sean, thank you for the honest feedback on the TB. I expected this to show less of a gain on a stock truck, so you have more to look forward to as you continue to mod. Keep us posted as you put some more miles on the truck.
09SMOKINHEMI
TEXAS
Got mine in yesterday. Hopefully I have time tomorrow to install and compare
sent from my Samsung Galaxy S3
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Need some updates from those that bought these. Please :)
$miley
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
This is an old thread...we have over 175 of these out now and they have been running great.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I like to do thread revival :)
Any better insight on how they due with mostly stock. I have a tuner which I use in stock mode an Afe filter and 4.56 gears I am debating between a better tuner with custom tune I could use or this.
$miley
Hemi450hp
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
With just a tuner, I would stick with the 85mm. On stock trucks, they perform about the same, but the 87mm really starts to pull away after you add an intake and headers with the tune. If you dont see yourself adding headers, then its best to save the extra $50 and just go with the 85mm.
audio1der
Airdrie, Alberta
Matt- are there instructions/video floating around showing how easy these are to install??
1500ram12
5.9L Cummins
Very easy to install. 4 bolts and a plug after removing the mid tube from air box
Sent from my DROID RAZR using Tapatalk 2
tigger54
