Got the valves done this morning and reassembled.
Glad to see a few more of yall guys following along
The intake is a 2186 performer.
I think A hipo fuel pump would be overkill for me. But if mine turns bad I'll definitely shoot ya a pm. As far as a 302 duration cam in a truck, wouldn't that be hard to live with? Any suggestions on this would be appreciated. If i swap cams I was considering a 262 or 268/something small with reasonable low to mid-range torque.
The guy I bought the truck from told me recently that the cam, lifters, and push-rods were all new but he doesn't remember specs because its been too long. He has a couple drag cars and a few classic dodge trucks (a 47 power wagon with a 3 cylinder cummins swap is his dd) I've been picking his brain more often now.
I'm going to pull my timing cover next and check my timing chain and see if i can get a grind # off the Camshaft. I think my motor may be over cammed already. It seems to barely pull at first, like it is struggling, then it pulls quickly to high rpm based on sound. But It may have just been a side effect of the general mis-maintence of the truck and poor engine swap job in general.
It was a 700$ truck, what could i have expected. I guess now i have more like 2k invested in it, and a lot of quality time. Still better than a new one imo
The truck rarely sees paved roads or the topside of 50 mph.
Other thoughts are that I could re-gear. and that my 727 needs serviced and a shift kit. It shifts way too early unless all out flooring it.
I'll keep you guys posted how it goes. And i forgot to get intake/carburetor studs and/or bolts. so I gotta look for those in town now too if i want to finish this anytime soon....
