My Experience with Marvel Mystery Oil
turkeybird56
Central Texas
Try som MMO in the gas - 4oz/10 gal and tell me the engine doesn't sound quieter!
HEY, my whole take on this topic: Your ride and do as yer wallet dictates. Not gonna get into better/worse etc. Your ride, yer wallet, be happy, LOL.
horace33
MN
97 dodge 18LARAMIE
My '18 w/ 60,000 had apparently been run for too long oil change intervals, I changed early & added marvel mystery oil, cleaned up my oil nicely in 3 oil changes.
M2 Pilot
eastern NC
hemi, 383
I don't use it but my Dad used to on the farm. I love the way it smells.
Jeepwalker
WI
2012 Reg Cab, 4x4
After 250k it's likely your O2 were probably past due for replacement. They don't last forever. Hard to say on your spark plugs w/o seeing them. How many miles, how much idling, how much highway speeds ..what kind of fuel??
The catalytic converters 'should' last longer, than 250k. Some people get way more out of catalytic converters, but hard to know what else could be going on. A leaking head gasket ...coolant really damages CC's. So, hard to say. Your cats could have conceivably been worn out anyway depending on factors we can't know. But more than likely they failed early (fouled) due to constant MMO oil going through them. A little bit of oil between long periods and the oil 'should' burn out of the cats. But putting any oil in the fuel tank, or diesel, etc routinely is like a vehicle that is 'burning oil'. And that does wear CC's prematurely.
There's really no reason to add anything to fuel. Just stick with Top Tier fuels and you'll be ok, unless there are other issues with a engine that need to be taken care of.
huntergreen
I don’t know enough about the subject, but I’ll just ask a question. Are you fixing one issue and causing others ? I’ll let you do your own research.
Zoe Saldana
california
6.4l
No, problems or issues with the engine. It makes a quiet engine purrrr.
Hope
Diesel 5.9
What are we doing wrong? 2005, 3500 Only gets 21 mpg….
