I will upload a picture hopefully today and yes it's on the backside of the frame cross member and the tie rods bolt up but the steering has been a little squirrelly. I've been replacing parts trying to figure it out when I first got it the alignment was way off and eating up the tires pretty bad so I did my own alignment which helped it was toe in at about 1 1/2" and I set it at toe in at 1/8" and it's not eating tires any more but still isn't right I replaced the tie rod ends, upper ball joints and control arms, lower ball joints, and replaced the rack and pinion. The boots were torn on both sides of rack and pinion when I got the truck and the boots split on both sides again after about 6 weeks so returned it under the part warranty and this time I installed the zip tie on the outer part of the boot behind the little lip deal on the inner tie rod so it would be able to slide back and fourth a little instead of the boot tearing when making turns. This was a couple weeks ago and so far the boots are ok but steering is still questionable. It drifts in the highway and doesn't have hardly any turn radius to speak of. Sorry for the novel and I'm going to move the rack and pinion asap. Thank you for the help
