My lightbar....
Tom88
The L brackets are 3" but I kind of wished I got the 4" since they a little bit thinker
Ok thanks Bud.
sking2001
43" Curved LED... boom
Custom install
sking2001
Random $50 lightbar on amazon... I didn't want to spend much on a light bar mounted that low if you catch my drift... I didn't go in with much expectations and I have to say it works fantastic for night off roading... So far no issues going on 6 months.... Also easier install than you think. Check this thread for my tips and tricks i used. http://www.ramforum.com/f41/install...4_sport_bumper-52690/index27.html#post1429852
olie03
2015 Dodge Ram 1500
5.7L Hemi V8
Here's mine
I'm looking at doing same thing as you, but it looks like my license plate hangs down infront of it a bit? mines a 2015 as well, did you have to modify it at all?
15RamTX
My plate had the plastic holder on it I just took that off and it fit fine
Sent from my LG-H918 using Tapatalk
olie03
2015 Dodge Ram 1500
5.7L Hemi V8
Here's my 42" light bar and led pods
Sent from my SAMSUNG-SM-N910A using Tapatalk
can you show a shot with light bar at night? thats exactly what Im thinking of doing. does the license plate get in the way?
Curlyp
OH
For those that have a 42" 560watt light bar, what wiring kit did you use? I cannot find one that supports a 560watt led light bar.
sking2001
I believe my 43" curved came with an array module and wiring harness so it wouldn't drain the battery. I don't have a night shot but I took this while installing it... I do not have a license plate holder on the front... My state doesn't require a license plate on the front, helmets, or beer goggles... Nothing finer than South Carolina woot woot
Bo Daggart
5.7L
Same bumper as mine and I have a 42" curved lightbar
Curlyp
OH
Thank you.
I bought a heavy duty 12 gauge 600W LED wiring harness with 60 amp relay. The light bar I bought was 560WATT.
Rzrman328
Rzrman328
The treeline
I used the two lower bolts that held the flipper vents and homedepot L bracket
TRIPLE-ROW LED Light Bar, POWLAB 28
Do you have any night output shots?
JB007Rules
Does anyone have any ideas for which brackets I could use for my 2012 RAM 1500 Big Horn Quad Cab? Thinking 50 or 52" curved up on the roof!
Could I be so fortunate to get no-drill brackets? Thoughts?
Oscar
Fredericksburg
7ca046f098e2ef75425a2fcec6dcf65f.jpg5026c02b9f43e344a8ca3be7907e0537.jpgf9a60d363a0d9e7c1545d731793e41a6.jpgfirst picture is headlight on next headlight and led bar and last picture Led bar only, I have 2 led bar they both turn on at the same time
Oscar
Fredericksburg
5415551daf9437aab0578ad37ae7d861.jpg70791e404b5552b72a88b67fa6ef8a12.jpg the 22" bar is on my bull bar and the 28 is behind the grill, The 22" did just fine but I felt like adding extra one just cause.
rgenereux420
WARWICK RI
2014 SPORT
Led grille
i need some help with wiring, i have projector headlights and i want to run three led lights off the daytime running lights and i want to make sure that it wont mess up anything. im placing the leds in the bottom grille and wanted to run them off the daytime lights so they are always on.
Rzrman328
Rzrman328
The treeline
Do you have pics of these LED lights?
joshuarb87
