My Power Ram 350
crazzywolfie
under the truck
for me i usually don't worry about the belts too much as long they don't look rotten. a few cracks here and their won't hurt anything. V-belts are pretty strong and you rarely hear about one failing unless something seizes up.
lol nope. it starts all on its own. it can just be a bit hard to keep it idling sometimes with the small vacuum leak until the choke is open enough or the engine is warm
RonJon '06
RonJon '06
Southern Minnesota
Dang choke. I thought I was on the right track but after my adjustment it wouldn't kick down. Then it started shooting flames out the tailpipe and while I was trying to figure out what was going on I noticed the passenger's side exhaust pipe was glowing red hot like the sun. :eek: I shut it down pretty quick lol.
crazzywolfie
under the truck
that don't sound good. i have never heard of a stock manifold glowing red. hopefully no damage was done.
RonJon '06
RonJon '06
Southern Minnesota
Oh, not the manifold but the exhaust pipe just below the manifold. I went back and adjusted it again and now it kicks down but the warm idle adjustment isn't working. I think I need to go back and start over from the begining.:crazy:
crazzywolfie
under the truck
i have still never heard of those glowing red. you would have to get things extremely hot to make a pipe glow red
RonJon '06
RonJon '06
Southern Minnesota
Yeah, it got pretty hot. The engine temp was OK but when I shut it off I could hear a gurgling sound on the top of the engine, maybe inside the intake manifold? I pulled the dipstick and the oil looked OK.
I think I might have my vacuum hoses hooked up wrong on the back of the carb because the choke pull off isn't working but the diaphragm seemed to work when I checked it. Daylight savings now so hopefully I can look at it tonight when I get home.
crazzywolfie
under the truck
well i would not trust the stock temp gauge. i found mine never worked that good or much at all. coolant could have possibly been boiling in the rad and flowing into the rad.
i don't really know those carbs too well so can't really help you out much. i barely know my way around a holley.
RonJon '06
RonJon '06
Southern Minnesota
Well, I was worried at first but I don't think the heads got hot. I'm pretty sure it was just dumping too much unburnt fuel into the exhaust. I might pull a plug on each side just to see but I bet they'll be as black as coal. The other reassuring thing is that my exhaust doesn't smell like coolant, it smells like gas big time.
crazzywolfie
under the truck
i meant the coolant might have boiled and went back into the overflow.
hopefully all it good. i have had my truck up over 230+ before and still seems to run good. the only issue at 230+ is my rad start leaking under pressure. i have just never seen an exhaust pipe glow red. the plugs should definitely tell you how hot your engine got tho.
RonJon '06
RonJon '06
Southern Minnesota
Fixed it. It was an open vacuum line on the back of the carb, the one that goes to the air cleaner but also to the choke pull off. No more flames out the tail pipe lol.
