need help installing line out converter!
lokal907ryder
wasilla, AK
ive read some threads but havent really found what i need. im going to be installing my amp and subs next week and i need to know what wires behind the stereo (8.4" non alpine) in my 2014 sport to connect the line out converter to. i know i need to hook it up to a left and right speaker. to me it seems easier to tap in behind the deck and leave the LOC behind the dash then run my RCA's like normal. also where should i connect my remote on wire for the amp? thanks for any help guys!!!
BlkRamRt
SoCal
HEMI 5.7
grab signal from the front door speakers and for the remote I used my cig lighter.
lokal907ryder
lokal907ryder
wasilla, AK
do you happen to know the wire colors? im going to install the LOC behind the headunit.
Bkhsvt
Chicago IL
Front left + grey/purple
Front left - grey/yellow
Bkhsvt
Chicago IL
Front right + dark green/purple
Front right - dark green yellow
Left rear + gray/lt green
Left rear - gray/dark green
Right rear + dark green/lt green
Right rear - dark green/gray
Bkhsvt
Chicago IL
You can join both your speaker inputs on your loc to just one speaker as well. So just put your pos impute and neg inputs together to one speaker.
lokal907ryder
lokal907ryder
wasilla, AK
youre the man. thank you!
EdmontonSS
Edmonton, AB, Canada
For a signal, I just went into the fuse panel, found the AC fuse, and slipped the wire in next to the fuse. its a tight fit and on a keyed power line :)
* Edit for question*
Here's a question for you speaker gurus. I have a LOC connected (or had it connected rather) to both back speakers for two inputs. Now, I only have it connected to the right rear door, and use only 1 set of inputs into the LOC. I dont know if there is a difference in sound (although it sounds a bit quieter).... should I be splicing the wires in two and filling both a left/right rear input slots on the LOC with the speaker wires from the right speaker, or just leave it on one input set.
The only reason i dont really care much, is I am getting a new Pioneer DD head unit on Wednesday and then can ignore the LOC. I had my truck broken into a couple weeks back and have been running the factory deck until I could source out a new head unit.
