need help lifting
elijah.rigby
el paso
So I just purchased this 2007 2wd 1500 QC I’m new with trucks so some guidance would help me a lot. I have done some research and I want to lift it 6inches. I have looked into pro comp and is considering, one question I have is about tires and rims. I was considering 37x12.50x17 at first but read where those rub, then I considered 35x12.50x17, then I read the lift kit "requires" 18" wheels and above. Could someone please clarify this for me?
usaf2006
Augusta, GA
Get a maxtrac 7" lift. Is equivalent to the 4wd 6" lift.
37s will fit with proper rims. Something like 17x8 rims with 4.5" backspacing. I don't know the reason why they recommend 18" rims. I've seen 6" lifted 4wds with 15" runs and 35" & 37" tires.
derekp
Buda, Tx
1990 5.9 Cummins
The wheel must be at least 17" because of the size of our calipers on these trucks. Anything smaller will not clear. Go with the maxtrac 7" lift. That's what I am running on my truck and I have 17x10 wheels with 35s.
E
elijah.rigby
el paso
I got my maxtrac 7inch lift installed, next will be wheels and tires
Sent from my SM-N910P using Tapatalk
Marciel
I agree with 35's being the right size for that lift, to many guys throw to much rubber under there and then they scrub. I have 17" wheels also, I don't like the low profile tire look myself.
Sent from my SM-N910V using Tapatalk
JustinRam1500
