Need Ideas on what to do
Cole Dandrea
Norwood MA
61494240_10156271531322157_555941107960119296_n.jpg 61233597_10156271531487157_4364131757117669376_n.jpg 61313745_10156271531622157_4722266179165487104_n.jpg Recently bought a set of American Forces 22x14 with Nitto Trail Grapplers LT355/40/22 that I can't even get a full wheel turn without rubbing. I also bought a set of Nitto 420s 305/40/22 but the stretch on the rims is sketchy to say the least. I have the 5100 Bistein leveling kit installed at 2.8. I'm not sure if i should wait out the back order on the Pirelli Zeros 335/35/22 or do a small lift and keep the Trail Grapplers. Guess I'm asking for opinions on what do. Any ideas would help.
Ohio5pt7
Ohio
Interested in seeing how this turns out I've been debating 14 wides with the 33x14.5r24 fury mts with my 3" motofab set up
Sent from my SAMSUNG-SM-G891A using Tapatalk
JB1
Houston, Texas
Rubbing on the fender or the front airdam?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
^ I was just typing the same question haha
By the looks it’s looking like the front lip.
My recommendation would be to add a 6” Zone lift with 3” rear coils. And lower the Bilsteins down
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
@Cole Dandrea American forces are true directional so the spokes should face the same way. 2 of them angle one direction and 2 angle the other for left and right sides. You have opposites on the passenger side.
Cole Dandrea
Cole Dandrea
Norwood MA
I didn't know that thanks! I was just test fitting to see where i would be rubbing, and yes it is the fender where i am rubbing. I was looking at the 6' zone lifts but i think I'm going to run the Pirelli PZero tire this year and go with the lift next year. Im trying to budget myself lol. How low would you lower the Bilsteins if i did the 3' rear coils?
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
That depends on your measurements now. The back will go up 3" the front will go up 5" simple math. If you go that route post your measurements and I will do the math for you. Glad I could help on the directional wheels :)
rwhjr
maryland
If you do your own work you could install a body lift and get clearance. Not sure if 1.5 or 3” would help you clear but it’d be a good cost effective way to stop the rubbing!
The body lift would only cost you several hundred dollars if you install yourself.
PS I love the wheels. A little more aggressive width/offset than I’d run but I like the Forces.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Do you have a scale, I’m curious what one wheel/tire weighs? Looks mean but also ridiculous, you’d need a huge lift so I’d either cut some metal to fit and/or drop some tire width at current height.
Ohio5pt7
Ohio
You want to know what it will take to clear it go to customoffsets.com a 4 " would clear your set up all day
