Need Immediate Help
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
IMO who ever put the wheel on should have tightened it. But the bottom line is it's your truck and your responsibility to have made sure the work was done right. Another example to do it right, do it yourself.
Tolson93
Tolson93
Northern MN
Yeah so I am out of luck.. I'm learning my lessons with this truck, cause now I have to buy stuff
Redtruck-VA
Virginia
Early this year I took the wife's ride in for it's annual state inspection. They take the wheels off to look at the brakes. When I got home I checked them and found both driver side wheels loose. It is what it is....
usaf2006
Augusta, GA
I didnt want to read all 23 pages but if ur rims are aluminum theyll contract and expand with the weather. Also they tend to loosen their lugs. I bought a cheap tq wrench from harbor freight and tq mine myself (even do my own work now).
Redtruck-VA
Virginia
Absolutely, I was torqueing mine to 95 lbs, but recently have gone to 115 lbs. and check them frequently.
Tolson93
Tolson93
Northern MN
Thanks guys , I'm hating myself for not getting them retorqued but guess I have to live and learn... I need other issues taken care of but I think getting this rim and my good tire back on is priority so I don't have to drive with this spare.
On the other note anyone know of a place to get cheap rims? Preferably a stock one to replace what I have
If you look closely you can see the holes are exactly a circle like they should be.
Sent from my iPhone using TapatalkView attachment 35214View attachment 35215
Redtruck-VA
Virginia
Too bad you aren't near, I have four nice 17" aluminum rims. But you need to post a picture of the rim that you are looking for as ther are a ton of different wheels. Salvage yard, ebay or Dodge Wheels Rims OEM Alloy Steel Wheel Rim
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
I read all of it and maybe I missed it...did you pull any plugs to check on it's condition? and what plugs are you running?
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
I just had my tires balanced and the tire guy mentioned that he tq'd them to 135 lbs..at the time I just nodded my head cuz I couldn't remember spec. I know over the years they (Dodge) kept raising it.
Redtruck-VA
Virginia
I agree, it's 135# now, which is just a tad bit more than I like.
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
when I go to track next month..it ain't gonna be 135 :) , prolly do the slicks at 120 or so..
as many times as I keep swappin wheels, I don't want to strip or cross-thread anything..
Redtruck-VA
Virginia
've used 95# for years and just recently went to 115#. I've never had any issues.
hemihustlin
Montreal
Very often what happens with alu wheels is the galvanic corrosion (the white stuff you find) between the wheel hub and the wheel itsself is not cleaned when the guy takes off the wheel. A good indicator is if you have to sledgehammer the wheel off the hub. If a good chunk ends up beween the wheel and the hub and the guy that is tightening them is not paying attention as he tightens (because it is obvious that the wheel is not torquing down properly) he torques to spec (if your lucky) then you drive off and as you drive the vibrations turn that chunk of corrosion into dust and now you have a 1/16 gap between the hub and the wheel. As you continue to drive the wheel nut slack gradually and soon enough you get a vibration and if you keep going you will scrap your studs and eventually lose your wheel.
Sounds alot like what happened here...
MyOhFive
HEMI
There is no way if he said he torqued them to 135 that ALL the lugs on that wheel would be lose. Not a chance in hell. The wheel was forgotten. I would definitely have brought that back to them and not left till i had a new rim/studs and free labour.
Tolson93
Tolson93
Northern MN
It's where I work too, they said they will get back to me to see what they will do...
Tolson93
Tolson93
Northern MN
Won't they use it against me that I didn't have it retorqued like they said to do?
Redtruck-VA
Virginia
That's a tough nut if you are dealing with your own shop. What was the original deal? Did you pay for the work or was it off the cuff? If you didn't pay for the work then you really are on your own. If you did pay for the work, then I would talk with the boss and tell him you want to be fair and have them pay for the parts you'll install them. Rear wheel I'm pretty sure you will need to pull the axle to get the old studs out. If they don't do the right thing by you, then take it as a lesson and look for another job... Good luck.. The whole situation sucks..
Tolson93
Tolson93
Northern MN
I paid 681$... Four tires, mounting balancing and a protection plan. Then they told me to come back and get them retorqued .. I didn't and this happened so that's everything
