Need some advice / help. JBA headers
Schmach
Communist California
5.7 4x4
Currently installing JBA ceramic shortys on my 2014 5.7 4x4.
Passenger side is done dust need to re torque after a few heat cycles. Drivers side I’m having issues.
1. Best tool or way to tighten the 2 most bottom rear next to the starter header bolts. Using ARP 10 mill heads.
I’ve used a flex head ratchet box and an off set box. Got them tight but not that tight.
2. Substantial exhaust leak. Same side driver. I believe front bottom front.
I can’t seemed to get it sealed up
Ticks at idle but is insanely loud under a load.
Tomorrow I’m pulling the driver side to start over.
Used gaskets that came with the JBA headers.
I do have copper RTV. Should I use that and coat both sides of the gasket.
I’m broke and have to do the work myself. Can’t take it to a shop.
Amateur gear/ motor head been wrenching most of my life.
DILLIGAF
Canada
The JBA included gasket goes in the trash. ;)
Get a Remflex gasket and ARP studs
Some of those bolts you can only get 1/8 turn at the time. Its a ***** but it seals.
S
Schmach
5.7 4x4
Does o Riley’s sell anything worth a damn Or Napa. I’ll check with them in the morning but super small town and usually have to order online.
As Ian stated get some Remflex 6022 Gaskets and a set of their 3" collector gaskets. The JBA bolts aren't to bad,so you can use them,but the Remflex gaskets will make your life alot better.
Highway
Ky
Yep, remflex gaskets and i used a 3/8” ratchet wrench, On a few a swivel socket. On my 03 i used felpro gaskets and worked out ok but after seeing and using remflex thats the way to go. Also did you put copper rtv where header connects to collector knuckle ?
S
Schmach
5.7 4x4
Yes I put copper RTV on the collector. No issues on both sides.
JustinRam1500
