new battery and still dies when i unhook charger/jumper box
Brevan
Ca
i put in a new battery today and the truck dies instantly when I take charger/jumper box off?
any thoughts or suggestions? truck has ben sitting for like 4-5 months
turkeybird56
Central Texas
Charging system issues. U gonna have to trouble shoot the system. Now, U know, could be a bad battery also, happens. But really sounds like charge system issue, all IMHO...
Brevan
Brevan
Ca
Terminals and leads are tight. Guess I'll take battery back to napa. Thx
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Did you figure this out?
So, just curious, do you have a multimeter? That would tell you the voltage on the battery. Possible they forgot to fill it and sold you a dry battery.
You would also be able to tell if the alternator is charging when its running on the jump pack.
I have not had a chance to read up on 3rd gen alternators, but I assume they need need a certain amount of voltage to establish the magnetic field that creates the current when the alternator spins, which is why it won't run on a dead battery and you can't get it running and then pull the battery like in the good old days.
Multimeters are so cheap and have so many uses, I can't imagine not having one.
