no turn sigs when brake is applied
kevinc
ont
hello everyone ,I have had an underlying issue where my turn signals
do not work while the brake lights are on,i can work them manually stil
i have replaced the bulbs in rear all four aswell as flasher units. it worked properly a few
weeks ago then resumed to not working.just before this issue occured i had been on
a forest access road bumpy as all heck and flooding swamps
hemihustlin
Montreal
Check your powers and grounds in your tail lights, if all are good, even when wet and shook up, buy a new socket, its shorting out inside!
CKH
Marietta, GA
5.9 Cummins
Could be the turn signal relay in the fuse box on the left side of the dash. Those things do all kinds of weird stuff when they go bad.
Orca
