No wipers - 99 Ram 2500
Discussion in 'Audio & Electronics' started by Marksman, Nov 21, 2016.
  1. Marksman
    Marksman Member
    78
    10
    Nov 14, 2014
    Ram Year:
    1999 Ram 2500 4x4 SLT
    Engine:
    V10
    Hey everyone. I've finally got my v10 truck where it's roadworthy, and I plan on trying to get it inspected tomorrow. Problem is, I replaced the dead wiper blades to find that the wipers don't function. I'm going to continue on my research, but I thought I'd post here in the meantime to see if anyone else has had the same issue. I checked the fuse and it's fine. I'll look and see if i can find a relay for it. Would it be more likely for the motor or switch to be bad? The truck has right at 200k on it if that's of any use. I don't see the wiper motor in the engine bay so i assume it's under the plastic cowl. Next thing I'll do is check to see if i have power to it.
    Thanks!
  2. MagSport
    MagSport Senior Member
    21
    1,256
    499
    Mar 10, 2014
    South Carolina
    Ram Year:
    1999
    Engine:
    5.9
    Look at your power lock fuse in the dash. If the CTM goes dead, the wipers will quit functioning.
  3. DodgeTx
    DodgeTx Senior Member
    628
    155
    Apr 29, 2015
    San Antonio
    Ram Year:
    2000
    Engine:
    5.9L
    had this happen when i didnt use them for a while. Thought i was hosed removed the wiper cowl and each wiper arm and tried them they worked. Put it all back together, and it still worked.
    I believe mine was binding somewhere and the jiggling of the wiper arms for removal freed them up. Worth a shot and good Process of Elimination
  4. Marksman
    Marksman Member
    78
    10
    Nov 14, 2014
    Ram Year:
    Engine:
    V10
    Thanks for the replies guys. The contacts in the switch were dirty and once i moved the switch back and forth about 50 times they came to life. Truck hasn't been on the road for close to 4 years now so i attribute it to that.
    Passed inspection without issue. It's officially alive.
    Now all I have to deal with are the electrical issues in the doors..
Share This Page
