Not using trailer brakes.
Meatball12
Carroll County, MD
So my uncle contacted me to see if I could haul this trailer(EMPTY) about 30 miles to his house. It is about 3800lbs empty. I have 1 question.
Would it be ok to haul this without hooking up the electric brakes seeing as how its not loaded. My truck does not have the 7 pin connector just the 4 pin.
If it is risky he says not to do it, but Im gonna be up that way anyway so I figured I would at least research the idea.
https://www.trailersuperstore.com/shop/carmate-8-5-x-20-enclosed-car-trailer-extended-tongue/
sandawilliams
Pueblo West, Co.
6.4 hemi
You should be OK if you take it easy and keep your speed down a little BUT many states require brakes on any trailer weighing more than 3000 lbs. total weight and many states require that if a trailer has brakes they must work.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
I dont know about where you live, but up here, If a cop spots either trailer brakes or a 7 pin connector, and its not plugged into the tow vehicle, he will pull you over.
Only pull during the day, as the lights dont work at night, if you want to be real sneaky, take the trailer plug and attach it somewhere inside the bed.
Meatball12
Meatball12
Carroll County, MD
Thanks for the feedback guys. I think I will do it. There are no highways on my route so I should be fine with speed. I'll grab one of those adapters so the lights work and I don't bring any undue attention.
I will have to wire up a 7 pin so I don't have this problem in the future.
Sent from my SM-G930P using Tapatalk
dudeman2009
Magnum 360
the question is now, which type of 7 pin do you have. I know of three alternate versions. One with brake and turns combines, brake and turns separate, then two variants where the aux and reverse lights are switched.
Just make sure you know which goes to what before you put it all together and blow a fuse, then start cursing
Meatball12
Meatball12
Carroll County, MD
I assume you mean on the trailer. Are there differently configuref adapters?
dudeman2009
Magnum 360
Administrator
Unless the trailer and truck has been custom wired for each other, there is two different standard 7 pin trailer connectors. The flat blade is the RV/trailer standard the other 7 pin uses round pins(agricultural/commercial)
https://www.etrailer.com/faq-wiring.aspx
dudeman2009
Magnum 360
thats the point, I dont know what his situation is. so I gave him the necessary information to determine which he has. the two are visually different but asking if he has a commercial connector or standard isnt much help if he doesnt know what one of them is.
Hence the picture describing the differences.
Meatball12
Meatball12
Carroll County, MD
It is a trailer off a dealer lot. I feel safe in assuming that it is a traditional connection. That pic is definitely helpful thanks.
Administrator
The way you wrote this, you make it sound like the 7 pin flat blade is wired differently. Despite the different color wires being used, the 7 pin Traditional and the RV Standard are wired the same.
The 7 round pin is wired differently.
Meatball12
Meatball12
Carroll County, MD
Thanks for the advice guys. The trip went well, however I definitely want trailer brakes next time. Going down one hill was a little bit hairy but I managed.
dudeman2009
Magnum 360
Man looking back at this I was a ******** to Crash, sorry man, I must have been tired or something. You are right, the RV and traditional styles of 7 pin flat have the same pinouts. I'm guessing that at the time I was trying to say that he shouldn't get confused if the wire colors don't match up exactly with each other on the trailer and truck.
Ftank
