chris52010trx4
So im not sure if its the battery or not... but upon start up it goes up to 1000 rpm.. then abit higher as if i have my foot on the peddle.. then drops slowly.. and as soon as I shift out of park.. it goes to about 3-400 rpm.. almost as if its about to bog out... I did a couple battery tests with a multimeter and OBD ... it said over charged at 12.80 when off and then after driving the truck for abit and checking it again it had said low voltage? Is this in any way related to my issue of starting and shifting out of park?? Im kind of at a stand still? battery is the original so 6 yrs old... No issue actually starting but all of a sudden this wierd **** is happening?? some say battery others say cam position sensor or would it be throttle body related?? I need some direction.
