Oil Change Intervals? Engine Sensor?
FullForceRam
Brentwood, Ca
5.7 Hemi 2WD Quad Cab
Hello fellas,
One thing I've definitely noticed with my truck, again being fairly new to the 5.7 hemi engine's in particular, is there a way to change the oil change notification To every 5000 miles or is there a sensor in the engine that senses when the oil needs to be changed due to lower viscosity levels, etc?
I typically always use 5W 20 synthetic and it seems that I'm changing oil every 3000 miles when it should last well over 5000 miles. Is there a way to modify the "oil Change" chime/notification on these trucks/engines?
Thank you in advance and any information would be greatly appreciated.
-Sam
DILLIGAF
Canada
It counts the amount of RMP used I think.
xb1230
Hobby Mechanic
South Shore of Montreal, QC, Canada
Easy way to figure it out... reset the message from the ECU without changing the oil and see how long it takes to come back.
If it is a viscosity sensor, which I doubt, it should come back almost right away. If not the next iteration should light up at relatively the same schedule (3000 miles in your case).
In any case, I would not exceed the recommended mileage at which the oil manufacturer recommends it to be changed.
Hope this helps
