oil consumtion, low rmp when stopped
Discussion in 'Engine & Performance' started by Seanram, Dec 9, 2016.
Sponsored By: Moe's Performance
  1. Seanram
    Seanram Junior Member
    23
    23
    Dec 9, 2016
    Ram Year:
    1997
    Engine:
    5.2 magnum
    hey i have a problem with my 97 dodge ram 4x4. it burn a qt 150miles ish. its drives great but when i slow down to a stop the rpm guage drop quarter inch then goes back to regular idle. i also have a oil problem! it dont leak not 1 bit of coolant or oil. i looked down throttle body was not clean had alittle bit of oil on sides. i noticed i had 1 drop of oil on end of exhaust.
    my thoughts are pcv or the intake gasket is leaking into exhaust.
    Please help me decide what to replace.
  2. dudeman2009
    dudeman2009 Senior Member
    22
    1,457
    166
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    In the engine and performance section, at the top, check out the plenum repair thread.
    Yeret likes this.
  3. dapepper9
    dapepper9 Senior Member
    22
    4,834
    1,867
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Rough startup?
  4. Seanram
    23
    23
    Dec 9, 2016
    Ram Year:
    1997
    Engine:
    5.2 magnum
    2 spins and she goes. My average psi is 130 and a high 180
  5. dapepper9
    22
    4,834
    1,867
    Feb 7, 2013
    Ram Year:
    2001
    Engine:
    5.9L V8
    Easy startup is a sign it's not valve seals. Id start with plenum and pcv
  6. Seanram
    23
    23
    Dec 9, 2016
    Ram Year:
    1997
    Engine:
    5.2 magnum
    it turns out i had oil in my intake pan.
  7. dudeman2009
    22
    1,457
    166
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    Engine:
    Magnum 360
    You will always have oil on the intake pan, thats just what the PCV valve does. But excess oil can be sucked in through a bad plenum gasket.
Share This Page
