Dean2
- Joined
- Jun 17, 2021
- Posts
- 2,803
- Reaction score
- 4,165
- Location
- Near Edmonton
- Ram Year
- 2021 2500
- Engine
- 6.4
Every oil thread on here says Mobile 1 does not meet the FIAT MS-6395 Certification for use in the 5.7. I decided to look on the Mobil site. According to that site they do actually meet this spec, so at least for the 5.7 you have Mobil 1 as an option. I could not find one of their oils that says it meets the MS-12633 spec for the 6.4 Hemi.
Mobil 1™ 5W-20
Advanced Full Synthetic Engine Oil
Keeps engines running like new
Protects for up to 10,000 miles between oil changes*
Mobil 1 5W-20 advanced full synthetic motor oil is designed to deliver outstanding engine protection, keep your engine running like new and protect critical engine parts for up to 10,000 miles between oil changes. *
Nothing outperforms Mobil 1 in overall performance, a motor oil which comes as standard equipment in many different vehicle models, including select high-performance vehicles.
Provides outstanding overall engine protection
Mobil 1 5W-20 motor oil is made with a proprietary blend of high-performance synthetic base stocks fortified with a precisely balanced additive component system, and meets or exceeds the industry's toughest standards
Mobil 1 5W-20 motor oil is recommended by ExxonMobil for use in all types of modern gasoline-powered vehicles (even those with high-performance, turbocharged, supercharged, multi-valve or fuel-injected engines), including:
Outperforms our conventional and synthetic blend oils
- Cars
- Trucks
- SUVs
- Vans
Mobil 1 5W-20 motor oil outperforms our conventional and synthetic blend oils. The advanced full synthetic formula can also help:
We stand behind our products
- Extend engine life
- Clean up engine sludge with active cleaning agents
- Deliver quick cold-weather starts with outstanding low-temperature capabilities
Please read our Mobil 1 limited warranty. Always check your owner's manual for the manufacturer's recommended oil viscosity grade, API service classification and any builder approval. You can also refer to the Mobil 1™ Product Guide for a quick look at key manufacturer approvals and info on the zinc and phosphorus levels in Mobil 1 5W-20.
If your vehicle is covered by a warranty, follow the vehicle's oil life sensor or the oil change interval recommended in your owner's manual. Proper maintenance practices, including frequently checking the oil level to ensure that the appropriate amount of oil is present, are required to ensure effective performance.
*Protects for 10,000 miles or 1 year, whichever comes first. For more information, read our Mobil 1 limited warranty.
Find a service location
Find at store
Features and Benefits
Mobil 1™ 5W-20 is made with a proprietary blend of high performance synthetic base stocks fortified with a precisely balanced additive component system. Mobil 1 5W-20 is designed to provide outstanding overall engine protection to keep your engine running like new, while meeting or exceeding the latest industry performance standards.
Key features and potential benefits include:
Features Advantages and Potential Benefits Advanced full synthetic formula Keeps your engine running like new Outstanding thermal and oxidation stability Protects for up to 10,000 miles between oil changes* Outstanding low temperature capabilities Quick cold weather starting and fast protection helps to extend engine life Active cleaning agents Designed to clean up sludge left behind in your engine Precisely balanced additive component system Unsurpassed wear protection
Applications
Mobil 1™ 5W-20 is recommended by ExxonMobil for all types of modern gasoline-powered vehicles, including high-performance turbocharged, supercharged, multi-valve fuel injected engines found in passenger cars, SUVs, light vans and light trucks.
• Mobil 1 5W-20 is a high-performance motor oil for all types of cars where this viscosity is recommended.
• Mobil 1 5W-20 is not recommended for 2-Cycle or aviation engines, unless specifically approved by the manufacturer.
Specifications and Approvals
This product has the following approvals: GM dexos1:GEN2 Licensed
This product is recommended for use in applications requiring: API CF Ford WSS-M2C945-A GM 6094M Ford WSS-M2C930-A Ford WSS-M2C945-B1 Fiat Chrysler Automotive MS-6395
This product meets or exceeds the requirements of: API SJ API SL API SM API SN ILSAC GF-6A API SN PLUS API SN PLUS RESOURCE CONSERVING API SN Resource Conserving API SP API SP Resource Conserving FORD WSS-M2C960-A1
Properties and Specifications
Property Grade SAE 5W-20 Flash Point, Cleveland Open Cup, °C, ASTM D92 234 Kinematic Viscosity @ 100 C, mm2/s, ASTM D445 8.6 Density @ 15.6 C, g/cm3, ASTM D4052 0.84 Kinematic Viscosity @ 40 C, mm2/s, ASTM D445 49 Pour Point, °C, ASTM D97 -51
