only reverse HELP!
zimtown
so after fixing the rear end AND the front end.... i got it all buttoned up and went to give it a whirl. no forward motion!?! i only have reverse now. and the tranny makes an awful whine at idle and continues as you rev motor. fluid is full. so i am pretty much deflated. any direction to go on the tranny?
specs i know: '00 1500 5.9 gas AT
thanks again folks
sullivan
Houston, Texas
Did you do anything to the tranny while you did the front and rear end work?
Check your drive shafts, transfer case to make sure all connections are nice.
ramhunter9
P-Star Jeep Wrangler
And check the linkage .. I bet that is the issue
ramhunter9
Well , did you find anything ?
