kkpsyop
I have a silver 2004.5 quadcab dually with 439,567 miles on it I am looking to sell. I would like your opinions on its value.
No body or frame rust. Supposedly it was in Louisiana for much of its life. I bought it at 364,000 miles and have since replaced the high pressure fuel pump, power steering pump, alternator, and all 4 brake calipers. The turbo blew so I upgraded to a Cheatah turbo around 390,000 miles. Upgraded all the tubing to new silicone with new clamps.
Engine started knocking so I had the engine rebuilt professionally at 404,000 miles to the tune of $12,500. All new everything, cylinders expanded 20 thousands and crank shaft turned. New head.
NV5600 6 speed transmission. It was hard to shift so I had AAMCO rebuilt it around 400,000 miles.
Curt 2,500 pound vertical weight trailer hitch which doesn't mind 4,000 pounds of vertical weight, according to the Cat scales. I installed Firestone air springs.
Replaced all battery cables with upscale military style a couple of years ago.
40 over injectors and South Bend dual disk Street clutch which I replaced a couple of years ago.
ARB head studs.
Smarty JR tuner that I'm afraid to adjust because right now the truck will pull a 34' deck over trailer with 2 Jeeps and a bunch of other stuff 75 miles per hour up mild hills at 1,100 degrees EGT.
I pulled that trailer with Jeeps on it 350 miles twice a year with no problems. Jeeps catch a lot of air and Cat scales say total weight 26,100 pounds.
Rear tires pretty new. Front tires don't have many miles left.
AC works, satellite radio.
So, what's it reasonably worth.
Sent from my Pixel 3 XL using Tapatalk
ARB head studs.
