overheating cummings
Discussion in 'Engine and Performance' started by CamoDieselPower, Mar 4, 2014.
Sponsored By: Moe's Performance
  1. CamoDieselPower
    CamoDieselPower Junior Member
    Mar 4, 2014
    Gulfport, MS
    Ram Year:
    2008
    Engine:
    Cummings 6.7
    when i go down the road the truck overheats and shoots out the coolant out of the reservoir untill there is about 1/4 of the coolant left in the radiator. when i slow down the truck cools down. im not getting any white smoke coming out of the exhaust. i have already replaced the water pump cause it got messed up and have already replaced the radiator and it still overheats.
  2. Power247
    Power247 Senior Member
    42
    5,502
    809
    Jul 26, 2012
    High Point, NC
    Ram Year:
    Engine:
    CTD 6.7
    Welcome to RF... I didn't see you mention so I thought I would ask the simple first... How about the thermostat? Did you replace it with the radiator or water pump? Hoses too?
    Also, you said no white smoke but are you getting and water in you engine oil?
    sent thru a cloud of smoke
  3. Bluesmoke91
    Bluesmoke91 2nd GEN Site Mod Staff Member
    3,160
    233
    Nov 26, 2010
    Baldwin Park, California
    Ram Year:
    Engine:
    if you did swap the t-stat. Did you make sure you put it in facing the correct way?
  4. NWRQC
    NWRQC Senior Member
    842
    86
    Sep 5, 2011
    Ram Year:
    Engine:
    What about any mods to your truck? You provide very little info in your post.
  5. NYCruiser
    NYCruiser Senior Member
    2,565
    789
    Dec 17, 2013
    Yonkers, NY
    Ram Year:
    Engine:
    How many miles? I've seen some tired diesels in the big rigs overheat under load from combustion gas getting into the coolant. Hope that's not the case.
  6. Trupiano
    Trupiano Registered User
    33
    10,982
    667
    Jun 27, 2010
    Hometown : Puyallup,WA Stationed : Little Rock,
    Ram Year:
    2010 Ram 2500 6.7L CTD Crew Cab
    Engine:
    6.7L CTD
    Is there a possibility that your head gasket is blown?
  7. smykowski
    smykowski Senior Member
    481
    28
    Nov 30, 2010
    Pacific, MO
    Ram Year:
    2010 SLT
    Engine:
    6.7L Cummins
    That's what I think. Especially when he said it blows all the coolant out of the reservoir.
  8. DannyMK2
    DannyMK2 Senior Member
    29
    1,724
    471
    Mar 25, 2013
    Long Island, NY
    Ram Year:
    2015 Power Wagon
    Engine:
    this is probably a dumb question, but did you bleed the air out of the system when you changed the water pump and radiator?
  9. smykowski
    481
    28
    Nov 30, 2010
    Pacific, MO
    Ram Year:
    2010 SLT
    Engine:
    6.7L Cummins
    The overheating part would make sense if there were air trapped in the cooling system. The fact that the system is becoming pressurized to the point it forces practically all the coolant out, sounds like the cooling system is part of the combustion chamber. BUT, you are right, bleeding the cooling system is good (and cheap) troubleshooting step vs. a new hg.
  10. DannyMK2
    29
    1,724
    471
    Mar 25, 2013
    Long Island, NY
    Ram Year:
    2015 Power Wagon
    Engine:
    ive had an air bubble shoot coolant out of the reservoir before.
Share This Page
