kobx02
- Apr 24, 2023
- 6
- 9
- Location
- Venice, Florida
- 2015
- 5.7L HEMI
2015 5.7L 98k miles. Getting the p308 code, intermittently.
I've replaced all spark plugs (prior to this code), and swapped cylinder 8 with cylinder 7 to see if that changed anything. I first noticed this code when chasing the infamous P0441 and P0457 codes back in early May. After replacing the gas cap, the PCV, the vapor canister, and the EVAP leak detection pump, finally got the CEL to stay off. As of May 16th, everything was OK until last Friday (6/30) the truck shut off after I remote started it. Low and behold the CEL was on, and it threw the p0308 code again. I cleared the code, and so far so good.
Next step is to swap a coil and see if it "moves"....but with it being so intermittent, I'm scratching my head. So my questions to the experienced techs are:
1. What else should I try?
2. Should I start suspecting lifter failure and thinking about removing the head for inspection?
