Hairy_pineapple58
Wondering if anyone has had this and how did you fix it?
I’ve changed out the ignition coil, swapped ignition coils and still get the code.
Plugs were changed about 10k miles ago. I’m sitting at 103k miles.
What are some of the symptoms of the code? Symptoms of a P2323 trouble code may include: Engine misfire Diminished engine performance Reduced fuel efficiency Other related codes Fuel injector operation for the affected cylinder may be disabled by the PCM What are some of the common causes of the code? Causes for this code may include: Bad spark plug wire or boot Malfunctioning relay or blown fuse (fusible link) Open or shorted wiring or wiring connectors (wildlife damage) Defective ignition coil Faulty camshaft or crankshaft sensor or wiring
