Parking light keeps popping up on my dash.
Soundshock07
Houston Texas
2017 ram 1500.
I replaced both back light sockets and both bulbs. I already checked my third brake light and yet it still comes on. Yes all the lights are working yet it tells me on my dash only when I have the night time lights on. I made sure they're all working just fine bulbs, sockets, properly put in correctly yet nothing. Any suggestions?
turkeybird56
Central Texas
OP, just what exactly are you asking and what is the problem?
ADDED: U guys are bad, lmao. :angels25::dancingpoop::favorites37:
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
I believe he is trying to say his dash lights have shat the bed multiple times. over the counter remedies like new bulbs aren't working as this seems to be a chronic issue, a real pain in the a$$ one might say. he's desperately looking for a solution before he really loses his schit over this issue that seems to just keep running on.
Personally I would have said it was a fiber issue, but I don't believe these lights run off fiber optics. So I think He really need to wipe the slate clean and start from scratch.
RamDiver
Marlborough, Ontario, Canada
I guess I don't need to evacuate any further in this thread.
Y'all have pretty much nailed that to the wall. :cool:
welcome.gif to Ram Forum, where the smart a$$ed energy thrives.
Just to clarify, do you have a park light indicator that illuminates on the EVIC but only during nighttime or low light conditions?
I trust all the headlights and signal lights behave properly, yes?
Do you see the same condition on the display when you manually turn the headlights on or off?
Could you post a picture of what you're seeing?
S
Soundshock07
Houston Texas
Yes all the lights are working properly. Yes even when I manually turn the lights on. I would but it's at random when my lights are on it decides to pop up.
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
2017 ram 1500.
My second thought is you might have the auto headlight function turned on and your lights are turning on automatically activating the dash light indicator
It could randomly be an issue with your dash illumination itself are there any other lights on your dash that stay on when your ignition key is turned on ?
S
Soundshock07
Houston Texas
Nope no other light on the dash. Even when I turn the lights on manually it appears. Even automatically still turns on regardless
RamDiver
What happens when you move the headlight selector to off?
I thought most of the US trucks have an off position, we don't in Canada.
Could you post a picture of the light you're seeing on the EVIC?
S
Soundshock07
Houston Texas
So I would take a picture but it's whenever it pops up randomly its not even in time sequence I can time to even take a picture.
S
Soundshock07
Houston Texas
My question is why does it keep showing as if a bulb is out when clearly all bulbs are working fine and sockets and the third brake light as well.
Dean2
Near Edmonton
Kind of hard to help someone who can't even manage a picture of the error light. Have you at least pulled the error codes. Outside of those two you are pretty much on your own. My crystal ball is all fogged up on this one.
S
Soundshock07
Houston Texas
Yeah tel me about it. I'm going to pull up the codes see if anything pops up
Dean2
Near Edmonton
Personally, that along with a fairly robust diagnostic porecdure, is sort of my first steps and long before I go looking for help from the good folks on here. Hope you find the problem.
Atcer2018
Virginia
Have you replaced the sockets? The sockets degrade over time and they are a replaceable item. Word of warning, our 4th gens don’t play nice with aftermarket rear sockets. Even the Dorman brand can be problematic. Best to stick with the OEM for a few bucks more.
