- Jan 17, 2016
- 14,057
- 24,372
- 14 Sport
- 5.7
Talk about causing me issues the last day and half. I stuck my old T1000 on our 300C a year ago ,and all i'm using it for is to up the idle rpm and the speed limiter,and for the last year it's been doing that with no issues.But this last week i had the battery disconnected a couple times while i swapped the 6.4 manifolds and mid pipes off my wifes 1320 onto it,and when i was done and it was back drivable, all of sudden it was turning on the Forward Collision Warning light,which put the car into limp mode,so i'm wondering what in hell i'd done when i'd did the manifold swap,i thought maybe i'd pinched a wire or something when i had the engine lifted off the motor mounts,so i spent last night chasing wiring down,looking for a buggered wire somewhere,but nothing was pinched or showing any signs of being distrubed,but it was still turning on the FCW warning lamp this afternoon,which got me wondering if it was something else,as it wasn't turning on any codes that my cheap code readers were picking up,or the diablo itself.So on a whim it made me start to wonder about the diablo,it took 3 trys before it finally restored the stock tune,which struck me a bit odd,as i'd restored the stock tune once before,and never had any issues,but finally after disconnecting the battery and letting it sit for a 1/2 hour,it finally restored the stock tune,and low and behold everything is working fine again,no forward collision warning light,and the car is back to running like normal.I never would have guessed the diablo would screw up the forward warning,but it appears like it did. So if you guys running a diablo ever run into a real oddball situation with no real explanation on why,for ****'s and giggles try restoring your stock tune,before you start thinking some sensor that's worth over a $1,000 Canuck has went south.Just my tidbit for today.My wife was about ready to choke me if i'd screwed up the summer cruising car,lol
